Normal Topic pdf export and diagram.CreateImage do not render image (Read 2564 times)
hans
Jan 24th, 2013 at 1:33am
When I export my diagram to PDF, or when I use Draigram. createImage, the images in my nodes are not present in my pdf or bmp.
Is there a workaround ?
Re: pdf export and diagram.CreateImage do not render image
Reply #1 - Jan 24th, 2013 at 10:21am
You will have to set the nodes' Image property. At this time images are not loaded from ImageUrl on the server side.
