Normal Topic Node tooltips on ImageMap show HTML (look fine in JavaApplet) (Read 1611 times)
jlj30
Feb 5th, 2013 at 8:44pm
I have specified tooltip text on all of my diagram nodes as follows:
node.ToolTip = "<html><div width='300' style='background-color: #FFFF99; font-size: medium;'>" + toolTip + "</div></html>";
The text renders fine when rendering the diagram using the JavaApplet, but shows the HTML in ImageMap mode.
Is this a bug, restriction or is there something else that I need to do to avoid the HTML showing in the tooltip?
Jim
Re: Node tooltips on ImageMap show HTML (look fine in JavaApplet)
Reply #1 - Feb 6th, 2013 at 6:54am
You will have to strip the html tags when in ImageMap mode. They happen to work in applet mode only because Java has built-in support for showing html-formatted tooltips.
