Normal Topic Scroll bar question (Read 1612 times)
lyrock
Scroll bar question
Feb 6th, 2013 at 2:57pm
I am having a few question about scroll bar. I found this thread:
http://mindfusion.eu/Forum/YaBB.pl?num=1338627740/0
I can't see my horizontal scrool bar after I installed my program on another computer. I can see it on my computer during debugging. (Vertical scroll bar is showing in these two cases)
Do I have to put diagram into a ScrollViewer control or a Ruler control in order to see the scroll bar?
Thank you for helps.
yan
Re: Scroll bar question
Reply #1 - Feb 6th, 2013 at 3:10pm
ScrollViewer is a WPF control, you cannot use it with the Windows Forms version. If your DiagramView has a fixed height, it might be clipped by the form if the other computer has a lower display resolution. Conversely, if it has higher resolution, the DiagramView might be larger than diagram.Bounds and there might be no need for horizontal scrolling, in which case the scrollbar will disappear. If you don't want that to happen, you will have to set view.HScrollbar.Visible = true every time after changing the diagram size or zoom level.
lyrock
Reply #2 - Feb 6th, 2013 at 3:25pm
You are always helpful! Thanks for the quick reply.
Have a great day!
