Normal Topic WinForm version - display negative ruler numbers on the left (Read 8719 times)
Kyle Chen
Feb 11th, 2013 at 6:00pm
Generally the ruler displays negative numbers on the left/top and positive on the right/bottom But in some special cases, we'd like to display inversely - negative on right/bottom and positive on left/top.
I've checked the source code, it's not difficult to implement. Is that possible to add a property for this in Ruler component in future release?
Thanks!
Re: WinForm version - display negative ruler numbers on the left
Reply #1 - Feb 12th, 2013 at 7:04am
We have this property to display Y coordinates negated in WPF:
http://www.mindfusion.eu/onlinehelp/wpfdiagram/index.htm?P_MindFusion_Diagrammin...
We can port it to Windows Forms for next release if that's what you need.
Kyle Chen
Reply #2 - Feb 12th, 2013 at 10:54pm
Actually I need NegatedX. If that possible? Thank you Stoyan
Reply #3 - Feb 15th, 2013 at 2:02pm
This version adds NegatedX and NegatedY properties to Ruler:
https://mindfusion.eu/_beta/fcnet_ruler_negated.zip
Kyle Chen
Reply #4 - Feb 19th, 2013 at 5:23pm
That's great! Thank you Stoyan, I will try that some days later. You're always so kind and fast!
Kyle Chen
Reply #5 - Apr 18th, 2013 at 8:04pm
Hi Stoyan,
Where is the NegatedX properties? I couldn't find it in latest WinForm flowchart (6.0.2). Can you look into it again? Thanks.
Kyle
Stoyo wrote on Feb 15th, 2013 at 2:02pm:
Reply #6 - Apr 19th, 2013 at 6:28am
Hi Kyle,
They are not available in an official release yet, we'll release them with v6.0.3 in a couple of weeks.
Kyle Chen
Reply #7 - Apr 19th, 2013 at 4:29pm
OK. Will wait, thank you.
Stoyo wrote on Apr 19th, 2013 at 6:28am:
Hi Kyle,
