Normal Topic Node Image Size Limit under Windows XP? (Read 1806 times)
Kyle Chen
Feb 11th, 2013 at 10:14pm
Is there any size limit for Image to display on Node? I tried set an image about 35000x100 to a node, it works fine under Windows 7 but failed under Windows XP. I wonder if there's any predefined limt of 32767x...?
Thanks.
Re: Node Image Size Limit under Windows XP?
Reply #1 - Feb 12th, 2013 at 7:21am
The control does not impose any limits, but GDI+ does. I think the max image size is about 10MB in XP (width * height * bpp). It's probably larger than that in 7. If you really need to render that large images, you can split them and either display the parts in TableNode cells, or use custom drawing to render them inside a ShapeNode.
Kyle Chen
Reply #2 - Feb 12th, 2013 at 3:34pm
Hi Stoyan,
Thank you. I guess so. I will make a limitation for WinXP of 32767x32767.
Have a good day,
Kyle
