Normal Topic Arrows fire too many SelectionChange events (Read 2388 times)
jabesc
Sep 22nd, 2006 at 1:59pm
I use the FLowchart.NET control to display relatively large graphs of data. When I select a node(s) I draw all relationships to other nodes with arrows. The relationships can be quite complex so I have many arrows showing with with the nodes (Flowchart.Box). The performance is excellent in all cases except when I do a multiple selection of nodes when there are already numerous arrows showing from a previous selection, each arrow in the new selection seems to fire the SelectionChange event 1 or more times. Case in point: I have a node with one arrow leaving the node, I select the node with the arrow also in the selection rectangle and then I get 5 SelectionChange events (only need 1). My question (finally) is, is there a way I can "unhook" the SelectionChange event from the arrows, so that only the boxes fire that event? Or is there some other way to deal with this issue?
Re: Arrows fire too many SelectionChange events
Reply #1 - Sep 22nd, 2006 at 2:09pm
If you don't need to let your users modify the arrows, you can set Locked = true for all arrows; that should prevent their selection.
If the SelectAfterCreate property is enabled, set it to false before creating arrows - otherwise the selection will change after you call CreateArrow, and that will probably raise SelectionChanged again.
jabesc
Reply #2 - Sep 25th, 2006 at 11:32am
Hi Stoyan,
That worked great. Multi selections now occur within a few seconds...
Thanks for your prompt response...
JAB
Reply #3 - Sep 25th, 2006 at 12:37pm
Hi there,
If the application creates many arrows while processing the selection, try how that will work with ValidityChecks = false; this too might improve the performance a bit.
