Normal Topic pathgradientBrush or radialgradientbrush (Read 3319 times)
hans
Feb 12th, 2013 at 4:31pm
Does canvas-diagram support PathGradientBrush or RadialGradientBrush  for setBackBrush() ?
The help shows:
var gradientBrush = { type: "LinearGradientBrush", color1: "green", color2: "white", angle: 30 };
Is there any documentation on how to create other gradientBrushes?
When I try this the diagram does not generate an eroor, but the backcolor turns black:
var gradientBrush = { type: "RadialGradientBrush", color1: "green", color2: "white" };
Re: pathgradientBrush or radialgradientbrush
Reply #1 - Feb 12th, 2013 at 7:10pm
They are not supported at this time.
Reply #2 - Feb 15th, 2013 at 12:30pm
This version lets you use radial gradients:
https://mindfusion.eu/_beta/jsdiag_radial.zip
For example:
var brush1 = { type: "RadialGradientBrush", color1: '#8ED6FF', color2: '#004CB3' };
var brush2 ...
brush2.colorStops = [
  { position: 0, color: 'red'},
  { position: 0.5, color: 'blue' },
  { position: 1, color: 'green' },
We'll implement some conversion between them and .NET's path graidents for the NetDiagram 5 release.
Reply #3 - Feb 20th, 2013 at 12:26pm
We have uploaded a new beta build that converts from .NET PathGradient brushes to canvas radial brushes:
https://mindfusion.eu/_beta/NetDiagram5.zip
