Normal Topic V5 Beta Issue - LinkShape (Read 1399 times)
jlj30
Feb 20th, 2013 at 8:54pm
I've installed the V5 beta which was suggested in another post to address an issue I was having with AJAX and the OnNodeClicked event firing unnecessarily.
The one thing I have noticed (and it's a big thing), is that the links look very different and are not at all what I want.
I have attached a PowerPoint slide deck with samples.
I would like to have the same look that I currently have.
I have tried:
  • link.Shape = LinkShape.Polyline;
  • link.Shape = LinkShape.Cascading;
  • link.Shape = LinkShape.Bezier;
None of these produce the look in my current diagrams.
Any suggestions?
Jim
NetDiagram_V5_Beta_-_LinkShape_Issues_-_20Feb2013.pdf (Attachment deleted)
Re: V5 Beta Issue - LinkShape
Reply #1 - Feb 20th, 2013 at 10:00pm
Doesn't the pre-beta image show the result of OrthogonalRouter? You might have omitted calling it with the beta. Or if you are distributing links along anchor points and then calling RouteAll, check if RoutingOptions.Anchoring is set to Keep.
