Normal Topic dragging around & cursor feedback calculation (Read 2414 times)
ulthien
Feb 26th, 2013 at 1:45pm
OK, a user drags our somewhat sizeable nodes around, and he will drop them so that they overlap - which we cannot allow.
So i feed back the cursor based on:
OverrideCursor =
(CanPlaceNode(MousePosition.X, MousePosition.Y, Selection.Nodes.Count)) ? Cursors.Hand : Cursors.No;
..which checks if geometry of the to-be-dropped node or nodes (selection) will overlap with some existing stuff, and shows a NO cursor when he drags.
This is placed in SelectionMoving handler.
Now, i noticed that the MousePosition (which we update from mouse moving handler) has an OFFSET to the nodes the user can drag around in diagram, i.e. he can fetch a node low or up, completely left or right and drag it so.
Is there a way to determine deltaX, deltaY difference between node's Upper Left corner & mouse drag point? That would help the CanPlaceNode method to better determine the potential overlap....
Maybe i have to store this deltas on the mouse down on a node (which is the onset of drag)?
Or is there some already better thought up solution?
cheers
Re: dragging around & cursor feedback calculation
Reply #1 - Feb 26th, 2013 at 8:00pm
Why not just check Selection.Bounds and Node.Bounds? They should indicate the current position of items in most situations.
ulthien
Reply #2 - Feb 27th, 2013 at 9:52am
so selection.bounds are updated along with the drag, too?
could not use it for drag of multiple nodes, as i arrange them to drop next to each other programatically. But its ok, i solved it per:
_dragGrabPnt = new Point(e.GetPosition(DocumentPlane).X - MouseNode.Bounds.X, e.GetPosition(DocumentPlane).Y - MouseNode.Bounds.Y);
in MousePressed aka drag begin; that way, i know the offset when a node is dragged around.
(pls close the thread Tongue)
cheers
Reply #3 - Feb 27th, 2013 at 11:54am
Yes, this seems to show correct values:
private void OnSelectionMoving(object sender, ValidationEventArgs e)
	Debug.WriteLine(diagram.Selection.Bounds);
