Normal Topic using v5 beta canvas mode: collapsed nodes not deleted (Read 2513 times)
hans
Feb 26th, 2013 at 4:16pm
I have a node with childnodes that are collapsed. When I delete the node, the childnodes are not deleted.
They remain invisible and unreachable.
I think they should be deleted with the parent, as the are in the applet mode?
Re: using v5 beta canvas mode: collapsed nodes not deleted
Reply #1 - Feb 26th, 2013 at 6:13pm
This won't be available in the current release. For the time being you can delete the child nodes from the parent's nodeDeleted event. E.g. if you are talking about containers:
function onNodeDeleted(sender, args)
	var node = args.getNode();
	if (node.children)
		Array.forEach(node.children, function (child)
			diagram.removeItem(child);
or otherwise loop over getAttachedNodes() if using groups.
