Normal Topic Dragging out of Diagram .. which event handlers can detect it dynamically? (Read 3023 times)
ulthien
Mar 1st, 2013 at 10:57am
when dragging in WPF the event handlers that would detect that diagram is left or entered, dragover etc are not receiving events until the drag is over aka mouse button is released.
This interferes with e.g. behaviour that the diagram we drag from keeps on scrolling (AutoResize) until the mouse is released, when the system determines "oh its ways outside the diagram" and stops scrolling.
What would be the way to note that mouse position is no more within the diagram WHILE dragging? How to get the real-time feedback?
thx
Re: Dragging out of Diagram .. which event handlers can detect it dynamically?
Reply #1 - Mar 1st, 2013 at 1:41pm
I suppose the system does not raise enter/leave events for controls that hold the mouse capture. You could check if the mouse is still inside the control from a MouseMove handler instead:
void diagram_PreviewMouseMove(object sender, MouseEventArgs e)
	var p = e.GetPosition(scrollViewer);
	var r = new Rect(0, 0, scrollViewer.ActualWidth, scrollViewer.ActualHeight);
	if (!r.Contains(p))
		Debug.WriteLine("out");
ulthien
Reply #2 - Mar 1st, 2013 at 2:49pm
nice Smiley
but how do you stop AutoResizing on this event?
i just tried AutoResize = AutoResize.None;
but it seems to continue scrolling. Maybe i should arrest the scrollviewer?
ulthien
Reply #3 - Mar 1st, 2013 at 2:53pm
i mean, it seems to have some leeway before scollviewer end is reached, sort of margin.
Reply #4 - Mar 1st, 2013 at 3:17pm
Is it auto-scrolling or auto-resizing at that point? - perhaps you should set the AutoScroll property to false... I'm not sure what you are trying to do - why not just keep these properties disabled, or do you need some sort of selective auto-scroll and auto-resize?
ulthien
Reply #5 - Mar 1st, 2013 at 3:36pm
I'll play a bit with it, does not look that bad as before Smiley
thx Stoyo
