Normal Topic Workflow Designer (Read 6336 times)
Peyman
I Really Love MindFusion!
Workflow Designer
Mar 4th, 2013 at 10:17am
after web searchs in internet i find your component for my program idea and download pro (still in trial).
but after 4 days i cant achive my idea Sad (my idea is similar to Workflow Designer Demo in Wpf section) so i want know
there is a possible way to implement Workflow Designer with Activex ? if yes you have any vb sample code ? or a piece of code ?
atall its a amazing component
thx for answer,
Peyman.
Re: Workflow Designer
Reply #1 - Mar 4th, 2013 at 11:09am
You can see how to implement drag-and-drop in the "Drag and Drop" and "More Drag and Drop" VB sample projects. This modification of the latter shows how to insert a node, splitting an existing link into two new ones, which happens in the WPF WorkflowDesigner example:
Private Sub FlowChart1_DropInDocVB(ByVal dataObj As FLOWCHARTLibCtl.IVBDataObject, ByVal docX As Long, ByVal docY As Long, ByVal keyState As Long, effect As Long)
    Dim s As String
    Dim b As FLOWCHARTLibCtl.box
    Dim i As Integer
    Dim a As arrow
    Set a = FlowChart1.GetArrowAt(docX, docY)
    If dataObj.GetFormat(vbCFFiles) Then
        'some file are dropped
        For i = 0 To dataObj.FileCount - 1
            s = dataObj.Files(i)
            Set b = FlowChart1.CreateBox(docX + i * 10, docY + i * 50, 250, 40)
            b.Text = s
        Next i
    Else
        'some text is dropped
        s = dataObj.GetData(vbCFText)
        Set b = FlowChart1.CreateBox(docX, docY, 100, 100)
        b.Text = s
        If Not a Is Nothing Then
            SplitLink a, b
        End If
    End If
    effect = vbDropEffectCopy
End Sub
Sub SplitLink(a As arrow, b As box)
    Dim a2 As arrow
    Set a2 = FlowChart1.CreateArrow(b, a.DestinationBox)
    a.Destination = b
End Sub
If you are interested in the sample layout code, it should be pretty straightforward to port. Our controls' API has evolved a lot since the ActiveX days, but you can still find one-to-one correspondence between the WPF and ActiveX members. E.g. a node.Bounds assignment will become a call to box.SetRect, and link.ControlPoints assignments will become arrow.CtrlPtX/Y assignments.
Peyman
Reply #2 - Mar 4th, 2013 at 5:59pm
thanks stoyo for quick answer and infos im going to download WorkFlow designer and try to convert it, maybe you can add this example in next version of Activex Smiley
thx anyway
Peyman
