Normal Topic Question about SaveToString method (Read 1019 times)
CanadaProgrammer
Mar 4th, 2013 at 10:14pm
string txt1 = diagram1.SaveToString();
string txt2 = diagram1.SaveToString();
txt1 and txt2 are different, i mean values are not equal.
I can use SaveToXml or parameter but it is not best way in my case.
Is there other way to make them same.
Re: Question about SaveToString method
Reply #1 - Mar 5th, 2013 at 7:56am
There isn't. The control uses some hashtables both internally for serialization and in the public API, and .NET iterates over them in indeterminate order.
