Normal Topic Throuble seeing images in pdf. (Read 2182 times)
Andy (CyT)
Mar 15th, 2013 at 1:53pm
Dear moderator,
We came out with this situation:
We use ShapeListBox with DiagramView.
We configure the elements.xml as follow:
(Sample node)
<shape id="NODO_ID" fill-mode="Winding" display-name="Comparar Variables">
  <outline>
      <line dash-style="Custom" width="-1">
        <point x="0" y="0" />
        <point x="0" y="100" />
      </line>
        <point x="100" y="100" />
      </line>
        <point x="100" y="0" />
      </line>
      </line>
    </outline>
    <image width="100" heigth="100" src="iconos/10.png"></image>
    <shape-decorations />
    <enable-outline>True</enable-outline>
</shape>
This makes an square outline with an image inside.
On the server side, we configured:
DiagramView1.Diagram.BackgroundImageAlign = MindFusion.Drawing.ImageAlign.Center;
then we check on the client side and the line below return 0, that is the correct
enum for ImageAlign.Center = 0
document.getElementById('DiagramView1').getDiagram().getBackgroundImageAlign()
So far works very well. But once we export to pdf, we experiment the follow:
if we don't set each ShapeNode.ImageAlign
1) we are unable to see the image at all in the .pdf
it is simply not shown
if we set each ShapeNode.ImageAlign = MindFusion.Drawing.ImageAlign.Center
two things happend.
1) The image saw in the pdf is at the very top of the square outline
   we can hardly see part of the image.
2) The image at the screen (not pdf) reduces it size, but remains centered.
this is the way we export to pdf
MindFusion.Diagramming.Export.PdfExporter pdf = new MindFusion.Diagramming.Export.PdfExporter();
pdf.AutoDetectEncoding = true;
pdf.Export(DiagramView1.Diagram, path);
we are using
Diagram component for .net Version 4.2
Warm regards,
Re: Throuble seeing images in pdf.
Reply #1 - Mar 15th, 2013 at 2:56pm
I can't see any problems with ImageAlign. Please attach your icon image here.
