Normal Topic LinkCrossings do not show up (Read 1826 times)
Dominic Hoffmann
Mar 20th, 2013 at 9:45am
Hi there,
i'm currently implementing a SwimLane Graph.
I am using the WPF Control inside a ElementHost with WinForms.
Now im having troubles with LinkCrossings.
They don't appear as i told the control with
Code (C++)
diagram.LinkCrossings = LinkCrossings.Arcs;
At every created link i'm setting following properties
Code (C++)
            link.Text = "some text";
            link.AutoSnapToNode = false;
            link.UseLayoutRounding = true;
            link.DrawCrossings = true;
            link.Dynamic = false;
            link.Shape = LinkShape.Bezier;
            link.TextStyle = LinkTextStyle.Rotate;
            link.Id = link_id;
So i thought that should it be.
Are there some other Properties to set or anything more to do?
If any further information is needed please tell me.
Thanks in advance for any suggestions.
As im no native english, please forgive me possible grammar mistakes Smiley
- Dominic
Re: LinkCrossings do not show up
Reply #1 - Mar 20th, 2013 at 10:31am
Unfortunately LinkCrossings is not supported for Bezier links at this time. It is hard to find the intersections points (see http://www.truetex.com/bezint.htm), and even harder to find end points for the arcs lying on the Beziers. We could implement some mode where Beziers are approximated via line segments and reuse the straight lines intersections code, but it will probably work very slow if the Beziers curves must be drawn with good enough quality (with large number of approximating line segments).
Dominic Hoffmann
Reply #2 - Mar 20th, 2013 at 10:41am
Thanks for your reply.
Now it's clear and it is not me doing something wrong Smiley
