Normal Topic Can I simply switch from ClientSideMode="ImageMap" to ClientSideMode="Canvas" ? (Read 1789 times)
jlj30
Mar 21st, 2013 at 7:25pm
We'd like our application to be more HTML 5 friendly and I was wondering what (if any) work is required to switch modes?
Are there any documented considerations in making such a migration?
Thanks in advance.
Jim
Re: Can I simply switch from ClientSideMode="ImageMap" to ClientSideMode="Canvas" ?
Reply #1 - Mar 22nd, 2013 at 6:56am
Canvas mode with AutoPostBack enabled should work very much like ImageMap with InteractivityExtender, though some events are still raised only on client side (e.g. clicked). There are some features from our .NET and Java libraries still missing from the JavaScript one though; you will have to check if everything you rely on is available in Canvas mode, e.g. check if classes and properties are listed under the JavaScript reference (http://www.mindfusion.eu/onlinehelp/netdiagram/index.htm?CC_refMindFusion_Diagra...). Some features we haven't implemented yet are 'dynamic' links, styled text, TreeViewNode class, built-in swimlanes.
