Normal Topic Rotary Stroke after the erase will split object not in the relative position of Diagram (Read 4260 times)
Joe
Mar 27th, 2013 at 3:51am
Rotary Stroke  after the erase will split object not in the relative position of the object in the Diagram
code:
eraseResult = line.GetEraseResult( rectEraser );
                    Diagram.Nodes.Remove(line);
                    foreach ( Stroke stroke in eraseResult )
                        PenNode pen = new PenNode( stroke );
                        pen.PenColor = line.PenColor;
                        pen.PenWidth = line.PenWidth ;
                        Rect newPosition = stroke.GetBounds( );
                        pen.SetBounds( newPosition , false , false );
                        pen.Opacity = line.Opacity;
                        pen.HandlesStyle = HandlesStyle.Custom;
                        Diagram.Nodes.Add( pen );
                        //pen.ZIndex = line.ZIndex;
Re: Rotary Stroke after the erase will split object not in the relative position of Diagram
Reply #1 - Mar 27th, 2013 at 6:51am
You might have to offset the Stroke's bounds as in http://mindfusion.eu/Forum/YaBB.pl?num=1320391922/11#11.
Joe
Reply #2 - Mar 27th, 2013 at 7:09am
thanks,but  I don't know how to calculate the offset value
Reply #3 - Mar 28th, 2013 at 7:05am
Check the FreeLine.Draw code in the post linked above. I assume the Stroke class you are using is from the InkCanvas API, right? And your PenNode class draws that stroke from its Draw override?
Joe
Reply #4 - Mar 28th, 2013 at 7:32am
Smiley yes , you are right.
code:
    public override void Draw(DrawingContext graphics, MindFusion.Diagramming.Wpf.RenderOptions options) {
            if (this.PenStroke == null)
                return;
            DrawingAttributes da = new DrawingAttributes();
            da.Height = this.PenWidth;
            da.Width = this.PenWidth;
            da.Color = this.PenColor;
            this.PenStroke.Draw(graphics, da);}
public StrokeCollection GetEraseResult(Rect rc) {
            return this.PenStrokeOrigin == null ? new StrokeCollection() : this.PenStrokeOrigin.GetEraseResult(rc);
eraseResult = line.GetEraseResult( rectEraser ); that it is used System.Windows.Ink,Do you have any solutions?
Reply #5 - Mar 28th, 2013 at 8:11am
So you can see how the FreeLine.Draw code offsets the stroke by applying a TranslateTransform in Draw:
graphics.PushTransform(new TranslateTransform(
	- strokeBounds.X, - strokeBounds.Y));
That code assumes the stroke points coordinates match the diagram coordinate system - check how the points are collected in the FreeLine.UpdateCreate override. If you are copying the stroke object from a separate InkCanvas control, you might also have to offset by diagram.Bounds.X/Y, and apply some scale if using a MeasureUnit different than WpfPoint.
Joe
Reply #6 - Apr 12th, 2013 at 12:55am
when i set the RotationAngle of object, erase the stroke that it will Deviations from the original position,not  the RotationAngle it work well,Where is the problem? Shocked
Reply #7 - Apr 12th, 2013 at 7:08am
What do you mean by erasing the stroke? Could you attach a test project showing the problem?
