Normal Topic let User created nodes be shapenodes (Read 3223 times)
Dominic Hoffmann
Mar 28th, 2013 at 7:53am
how can i manage to let nodes created by the user, look the same like the nodes i created programmatically by diagram.Factory.CreateShapeNode?
Re: let User created nodes be shapenodes
Reply #1 - Mar 28th, 2013 at 8:14am
Copy the code you are using to customize nodes after CreateShapeNode to a method taking ShapeNode parameter, and call it both from InitializeNode/NodeCreated event handler and after CreateShapeNode.
Reply #2 - Mar 28th, 2013 at 8:20am
... and set Behavior to LinkShapes or DrawShapes to be sure the user draws ShapeNodes in the first place.
Dominic Hoffmann
Reply #3 - Mar 28th, 2013 at 8:23am
ok, i didn't clearly explain my problem. Sorry.
If i create nodes by CreateShapeNode they get a rounded Shape with Aero and Glass Effect which i have applied to NodesEffect.
But if a user is creating a node, it only appears with a white reactangle shape.
After creating a node programmatically i am not calling any methode which would affect the look and feel of the nodes.
Thanks for your help.
Dominic Hoffmann
Reply #4 - Mar 28th, 2013 at 8:34am
Stoyo wrote on Mar 28th, 2013 at 8:20am:
ok, i think you posted that, while i was writing my post.
I will have a try, maybe thats the thing i am missing.
Dominic Hoffmann
Reply #5 - Mar 28th, 2013 at 8:41am
As i thought, thank you.
And the real funny thing (not really Wink ) is, that this missing option has been excactyl the next one in the drop down menu of Behaviour Enum which i already had set *arg*
