Normal Topic ResizeToFitItems doesn't show all diagram items (Read 1876 times)
Rich Cassell
Mar 28th, 2013 at 9:47am
I apologise if this has been asked in the past; i've had a flick through previous posts and found things similar but not exactly what i'm struggling with.
Basically, i am using a treeLayout and after calling Arrange on the diagram i am then calling doc.ResizeToFitItems(5). This works fine in that it moves everything into the viewable area (i.e. moves it down and right so that it's not out of bounds), obviously with a gap of 5.
The problem is, i actually want it to resize the panel so that all items can be seen at the same time. I.e. The scroll bars are not needed. I use the DiagramView zoom facility so after an Arrange i can zoom out until i can see all of the items and the scrollbars disappear - but i'd like it to do this automatically after an Arrange - what am i missing?
Any help would be great!
Cheers,
Rich
Re: ResizeToFitItems doesn't show all diagram items
Reply #1 - Mar 28th, 2013 at 10:15am
Try also calling DiagramView.ZoomToFit().
Rich Cassell
Reply #2 - Mar 28th, 2013 at 10:27am
Hi Stoyan,
Works a treat! Smiley Thanks very much.
Rich
