Normal Topic Error Handling in the Calendar Control (Read 2068 times)
Achim
MindFusion rocks!
Apr 4th, 2013 at 9:55am
Hi there,
after working some time with the control (dragging and dropping items in the resource view) I'm getting an error which seems to be internal to the control. The whole surface gets white with a red border and red crossed lines.
Is there any way to get access to the exception that caused the problem?
Best regards
Achim
Re: Error Handling in the Calendar Control
Reply #1 - Apr 4th, 2013 at 10:25am
This usually happens when there is an error in GDI+. Try disabling your custom drawing code (if you are using any) and see if the problem will happen again. You can also enable breaking on first chance exceptions inside Visual Studio (Debug > Exceptions) and provide me with the stack trace of the exception when it is thrown.
