Normal Topic Cannot draw Cascading links (Read 3247 times)
mandz
Apr 17th, 2013 at 4:14am
I want to use the cascading shape for my links.  I'm setting it in 2 places.  Once on the diagram before adding any nodes or links (diagram.LinkShape) and again for each link (link.Shape).  I'm also arranging the nodes automatically (layout.Arrange(diagram).  Problem is that the nodes are shown with the default Polyline.  Though newly added nodes (drawn on the surface) are drawn with Cascading lines.  How can I get the original links drawn dynamically to also display as cascading lines?
Re: Cannot draw Cascading links
Reply #1 - Apr 17th, 2013 at 7:54am
Layout algorithms change the link shape to a value corresponding to their own properties such as LinkType in LayeredLayout or RoundedLinks in OneWayLayout. If the layout classes you are using do not support cascading links, you will have to loop over diagram.Links after calling Arrange and reset link.Shape back to Cascading.
mandz
Reply #2 - Apr 17th, 2013 at 11:19pm
Thanks Stoyan, this did the trick:
layout.LinkType = LayeredLayoutLinkType.Cascading;
