Normal Topic setCancel not bringing back the children back to original position (Read 4463 times)
Kiran B
Apr 19th, 2013 at 11:24pm
I am having a container node and the container is having some children inside. Based on some logic on the onNodeModifying event i am calling args.setCancel(true). The problem is the container is coming back to the original position, but the children are not coming back to the original position.
function onNodeModifyingScript(sender, args) {
Kiran B
Re: setCancel not bringing back the children back to original position
Reply #1 - Apr 22nd, 2013 at 10:08am
For the time being, override the following ContainerNode methods as work-around:
var ContainerNode = MindFusion.Diagramming.ContainerNode;
ContainerNode.prototype.startDrag = function (ist)
	ContainerNode.callBaseMethod(this, "startDrag", [ist]);
	Array.forEach(this.children, function (child)
		ist.originalStates.set(child, child.saveLocationState(ist));
ContainerNode.prototype.cancelDrag = function (ist)
	ContainerNode.callBaseMethod(this, "cancelDrag", [ist]);
		child.restoreLocationState(ist);
Kiran B
Reply #2 - Apr 22nd, 2013 at 10:55am
Thanks Stoyan. Now its works, but only bringing the immediate children back. How to bring back the nested children also?
Reply #3 - Apr 22nd, 2013 at 2:23pm
Try this version of the methods instead:
		child.startDrag(ist);
		child.cancelDrag(ist);
Kiran B
Reply #4 - Apr 23rd, 2013 at 5:03am
Hi Stoyan,
Now i am not able to move the container to anywhere in the diagram.
I am having a container node with some child nodes which is inside another container(Parent Container).
Now the Parent Container is not able to move or re-size inside the diagram.
Kiran B
« Last Edit: Apr 23rd, 2013 at 6:04am by Kiran B »
Reply #5 - Apr 23rd, 2013 at 6:35am
Hi Kiran,
The code above does not prevent you from moving containers. Perhaps your nodeModifying handler sets the Cancel flag for that container?
Kiran B
Reply #6 - Apr 23rd, 2013 at 8:27am
Hi Stoyan,
Sorry man. The code is working fine. There was some issue with my code in setting the bool value for setCancel method.
Kiran B
