Normal Topic Exception is raised in new version (Read 3480 times)
Yogendra
Apr 22nd, 2013 at 5:39am
Hi Stoyo,
I am working with diagram and using new version. I have analysist in previous version, There are some exception is raised. Exception is as mentioned
Stack Trace of Exception:
at MindFusion.Diagramming.InteractionState.IsAllowed(Point point)
at MindFusion.Diagramming.BehaviorBase.OnMouseUp(MouseButtonEventArgs e)
at MindFusion.Diagramming.Diagram.x66c89b500bffc63d(Object xe0292b9ed559da7d, MouseButtonEventArgs xfbf34718e704c6bc)
at MS.Internal.CoreInvokeHandler.InvokeEventHandler(UInt32 typeIndex, Delegate handlerDelegate, Object sender, Object args)
at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, Int32 actualArgsTypeIndex, String eventName, UInt32 flags)
I have already posted this question. Link is here:-
http://mindfusion.eu/Forum/YaBB.pl?num=1364227632
and you said to me use new version to overcome this problem. So i am using new version but i have still this problem.
Please suggest me something...
Thanks in advanced.  Smiley
Re: Exception is raised in new version
Reply #1 - Apr 22nd, 2013 at 8:15am
Our developer could not reproduce this with latest version and your code from previous post. Please check this test project and let me know if we should change anything to reproduce the exception:
https://mindfusion.eu/_samples/exception_test.zip
