Normal Topic Deleting container node not deleting the children side that (Read 3246 times)
Kiran B
Apr 24th, 2013 at 9:48am
When i try to delete the container node which is having nested children, it is deleting the container from diagram but not the nested children.
How can i achieve this? Ideally it has to be included in the Mindfusion framework right?
I am using below code to remove the item
function removeSelection() {
        var diagram = $find("diagramView1");
        var selectedItems = diagram.getSelection(); //returns both nodes and links
        if (selectedItems) {
            for (var i = selectedItems.items.length - 1; i >= 0; i--) {
                if (selectedItems.items[i]) {
                    diagram.removeItem(selectedItems.items[i]);
Kiran B
Re: Deleting container node not deleting the children side that
Reply #1 - Apr 24th, 2013 at 10:39am
This function removes a container togehter with child nodes, handling nested containers too:
function removeItem(item)
	if (item.children)
		Array.forEach(item.children, function (child)
			removeItem(child);
	item.getParent().removeItem(item);
Not necessarily, keeping the child nodes seems a valid enough use case Smiley
Kiran B
Reply #2 - Apr 24th, 2013 at 11:43am
Hi Stoyan,
I agree with your point "keeping the child nodes seems a valid enough use case"
But can't you expose a property to configure that?
Because deleting children while deleting the container is also a valid use case. Probably this is the straight forward use case.
What you say?
Kiran B
Reply #3 - Apr 25th, 2013 at 5:41am
We'll have it in mind for next releases Smiley
