Normal Topic Text goes out of the shape if content is very long (Read 2057 times)
Kiran B
Apr 29th, 2013 at 9:21am
The text entered in the shape node is going outside the shape and it looks really ugly. Is there any way to show the text within the shape? If the text is too long show only the text which can be shown inside the diagram, the rest can be trimmed off. Is there any hack for this?
Kiran B
Re: Text goes out of the shape if content is very long
Reply #1 - Apr 29th, 2013 at 11:13am
You could trim the text by overriding our wrapLine function:
var Text = MindFusion.Drawing.Text;
var originalWrap = Text.wrapLine;
Text.wrapLine = function (context, text, maxWidth, lines)
	originalWrap.apply(this, [context, text, maxWidth, lines]);
	for (var i = 0; i < lines.length; i++)
		var line = lines[i];
		while (context.measureText(line).width > maxWidth)
			line = line.substring(0, line.length - 1);
		lines[i] = line;
With this version you could also call node.resizeToFitText(FitSize.KeepRatio) to make the node large enough to fit its text:
https://mindfusion.eu/_beta/MvcDiagram15.zip
