Normal Topic OnContainerChildRemoving event (Read 5739 times)
Kiran B
Apr 30th, 2013 at 7:18am
I wanted to prevent a shape not to move out of the container node. I don't want that shape to get adedd to a child container also.
So what i am thinking is to do the logic in onContainerChildRemoving event and do a setCancel. Since Mindfusion is not exposing this event, what is the ideal way to achieve this. I dont want to handle this in OnModifyingEvent.
I want to do soemthing similar to the below scenario.
http://mindfusion.eu/Forum/YaBB.pl?num=1367226820
Is there any method i can override inorder to achive this.
Kiran B
Re: OnContainerChildRemoving event
Reply #1 - Apr 30th, 2013 at 6:01pm
You can override the container.remove method the same way as the add one:
var originalRemove = ContainerNode.prototype.remove;
ContainerNode.prototype.remove = function (node, raiseEvent)
	// filtering code
	originalRemove.apply(this, [node, raiseEvent]);
There's nothing wrong in cancelling the operation from modifying event, that will also show a stop cursor:
var node = args.getNode();
var ctrBounds = node.container.getBounds();
var childBounds = node.getBounds();
if (!ctrBounds.contains(childBounds) &&
	!ctrBounds.intersectsWith(childBounds))
	args.setCancel(true);
Kiran B
Reply #2 - May 8th, 2013 at 6:19am
Hi Stoyan,
The below code is not working in the below 2 scenarios.
1. I am having a container node. Another container node is inside that. Here in this case i am able to drop shapes form parent container to child container
2. One container node is overlapping with another container node. Here i am able to drop shapes in the overlapped region
How can i fix these 2 also?
Kiran B
« Last Edit: May 9th, 2013 at 4:03pm by Kiran B »
Reply #3 - May 9th, 2013 at 6:08am
What code exactly is not working?
Kiran B
Reply #4 - May 9th, 2013 at 6:08am
Hi Stoyan,
Is There any update for this?
Kiran B
Reply #5 - May 9th, 2013 at 10:21am
What exactly is the "code below" that's not working?
Kiran B
Reply #6 - May 9th, 2013 at 12:36pm
Sorry Stoyan,
This is the code i am using. Same code you have given
Kiran B
Reply #7 - May 9th, 2013 at 4:45pm
Try this version instead:
function onNodeModifying(sender, args)
	if (node.container)
			return;
		var nodes = sender.getNodesAt(args.getMousePosition());
		for (var i = nodes.length - 1; i >= 0; i--)
			var test = nodes[i];
			if (test == node)
				continue;
			else if (test == node.container)
				return;
			else if (ContainerNode.isInstanceOfType(test))
				return;
