Normal Topic HandlesStyle DashFrame and the move hit test (Read 1683 times)
j poz
May 2nd, 2013 at 4:35pm
If I set a ShapeNode to have the DashFrame handles style, there is an area near the inside border but before the center of the node that if I click, it does not allow me to move the tool, instead attempting to select tools.
On the other hand, if you set the handles style to EasyMove, it allows you to select anywhere in the tool (except the resize handles) to move the tool.
How can I make the DashFrame act like the EasyMove when it comes to the moving the tool hit test?
Re: HandlesStyle DashFrame and the move hit test
Reply #1 - May 2nd, 2013 at 7:56pm
That area is reserved for drawing links, and the nodes' hit-testing code returns negative result indicating that the behavior class should do its default operation, which might be selection in some modes. You could set HandlesStyle to Custom instead, and implement events as follows:
void OnDrawAdjustmentHandles(object sender, MindFusion.Diagramming.DrawItemEventArgs e)
	var node = (DiagramNode)e.Item;
	var style = node == diagram.ActiveItem ?
		diagram.ActiveItemHandlesStyle :
		diagram.SelectedItemHandlesStyle;
	InternalUtils.DrawSelHandles(
		e.Graphics,
		style,
		diagram.DisabledHandlesStyle,
		node.Bounds,
		node.RotationAngle,
		node.EnabledHandles,
		true,
		HandlesStyle.DashFrame,
		diagram.AdjustmentHandlesSize);
void OnHitTestAdjustmentHandles(object sender, HitTestEventArgs e)
	node.HandlesStyle = HandlesStyle.DashFrame;
	int handle = -1;
	node.HitTestHandle(e.MousePosition, ref handle);
	if (handle == -1 && node.ContainsPoint(e.MousePosition))
		handle = 8;
	e.HitResult = handle;
	node.HandlesStyle = HandlesStyle.Custom;
Alternatively, use a custom behavior class that starts a move operation if hit-testing code returns -1 but mouse pointer is inside the node.
