Normal Topic DocumentViewer's search function does not work (Read 6574 times)
luolishuang
May 3rd, 2013 at 2:41am
The lower left corner of the search function in DocumentViewer can not be used,Can this be solved??
Re: DocumentViewer's search function does not work
Reply #1 - May 3rd, 2013 at 6:01am
The WPF DocumentViewer's search function do not appear to work with FixedDocument documents. You can convert the FixedDocument created by MindFusion.Reporting to an XPS document and show this XPS document in the viewer. The following method can help you convert FixedDocument objects to XPS:
private IDocumentPaginatorSource FixedToXps(FixedDocument doc)
	var stream = new MemoryStream();
	var documentUri = new Uri("pack://document.xps");
	var p = Package.Open(stream, FileMode.Create, FileAccess.ReadWrite);
	PackageStore.AddPackage(documentUri, p);
	var xpsDoc = new XpsDocument(p, CompressionOption.NotCompressed, documentUri.AbsoluteUri);
	var dw = XpsDocument.CreateXpsDocumentWriter(xpsDoc);
	dw.Write(doc);
	return xpsDoc.GetFixedDocumentSequence();
Note, that you need to add references to ReachFramework.dll and System.Printing.dll assemblies in order to compile this method.
