Normal Topic Tutorial not clear (Read 6370 times)
mandz
Tutorial not clear
May 8th, 2013 at 3:31am
After following your advice as in this post: http://mindfusion.eu/Forum/YaBB.pl?num=1366070876/2#2, I tried your first tutorial (http://www.mindfusion.eu/onlinehelp/jsdiagram/index.htm), but it does not make sense.  At what stage is the Javascript code called?
This is my code:
Code (HTML)
    ViewBag.Title = "Index";
<script src="MicrosoftAjax.js" type="text/javascript"></script>
<script src="MindFusion.Diagramming.js" type="text/javascript"></script>
<script src="Tutorial1.js" type="text/javascript"></script>
<h2>Index</h2>
<!-- The Diagram component is bound to the canvas element below -->
<div style="width:900px; height:500px; overflow:auto; border: 1px solid;">
<canvas id="diagram" width="2100" height="2100">
    This page requires a browser that supports HTML 5 Canvas element.
</canvas>
</div>
and the JS:
Code (Javascript)
var Diagram = MindFusion.Diagramming.Diagram;
var DiagramLink = MindFusion.Diagramming.DiagramLink;
var ShapeNode = MindFusion.Diagramming.ShapeNode;
var Rect = MindFusion.Drawing.Rect;
var LayeredLayout = MindFusion.Graphs.LayeredLayout;
var diagram;
Sys.Application.add_load(function (sender, args) {
    // create a Diagram component that wraps the "diagram" canvas
    diagram = $create(Diagram, null, null, null, $get("diagram"));
var request = new Sys.Net.WebRequest();
request.set_url("TextFile1.txt");
request.set_httpVerb("GET");
request.add_completed(onResponse);
request.invoke();
function onResponse(executor, eventArgs) {
    if (executor.get_responseAvailable) {
        var json = executor.get_responseData();
        var graph = Sys.Serialization.JavaScriptSerializer.deserialize(json);
        buildDiagram(graph);
function buildDiagram(graph) {
    var nodeMap = [];
    var bounds = new Rect(0, 0, 18, 8);
    // load node data
    var nodes = graph.nodes;
    Array.forEach(nodes, function (node) {
        var diagramNode = diagram.getFactory().createShapeNode(bounds);
        nodeMap[node.id] = diagramNode;
        diagramNode.setText(node.name);
        diagramNode.setBrush("LightCyan");
    // load link data
    var links = graph.links;
    Array.forEach(links, function (link) {
        diagram.getFactory().createDiagramLink(
            nodeMap[link.origin],
            nodeMap[link.target]);
// arrange the graph
var layout = new LayeredLayout();
layout.nodeDistance = 10;
layout.layerDistance = 10;
diagram.arrange(layout);
As you can see, I'm not a JS developer, but a C# and your tutorial is really very vague.  Any chance that you could add the source code for your examples to the tutorial pages?  Thanks
Re: Tutorial not clear
Reply #1 - May 8th, 2013 at 8:35am
You can find the full source code in the "samples\tutorial1.js" file in the folder where you unzipped the JsDiagram archive. From what I can see, the difference from your code is that ours runs the request from within the load handler (this corresponds to a Page_Load or Window_Load handler in C# code):
	diagram.setLinkHeadShapeSize(2);
	// pretent we are calling a web service
	request.set_url("Tutorial1.txt");
	request.invoke();
mandz
Reply #2 - May 9th, 2013 at 12:30am
I have 5 tutorials in my samples.zip file, but they are the MVC ones.  I wasn't aware that I need to install the Javascript components to see an example of how to build the diagram on the client side with the MVC controls.  I'll download and install that too.  Thanks
