Normal Topic Documentation problems (Read 1655 times)
Rennie
May 8th, 2013 at 4:38am
Starting a new thread ...
http://www.mindfusion.eu/onlinehelp/flowchartnet/T_MindFusion_Diagramming_WinFor...
Doesn't list Scale as a property - just mentions it in the remarks for ScaleToPage.
http://www.mindfusion.eu/onlinehelp/flowchartnet/P_MindFusion_Diagramming_Render...
and
"A float value specifying the scale factor of the print output."
Doesn't mention that the value is a percentage, with a default value of 100, leaving you to assume that it really is a "factor", i.e., has a default value of 1.0.
http://www.mindfusion.eu/onlinehelp/flowchartnet/M_MindFusion_Diagramming_WinFor...
and
The remarks look like they are mistakenly copied from PrintPreviewEx.
Enough for now ...
Rennie
Re: Documentation problems
Reply #1 - May 8th, 2013 at 8:55am
Another one:
http://www.mindfusion.eu/onlinehelp/flowchartnet/P_MindFusion_Diagramming_Diagra...
"The default is ImageAlign.Document."
That must be an old value - it doesn't exist anymore. Current default is ImageAlign.TopLeft.
Reply #2 - May 9th, 2013 at 6:04am
Scale is inherited from RenderOptions and you can find it listed along with more properties on the RenderOptions members page. Usually inherited members of a class are listed too, but we now see our help software does not do that for classes in different namespaces as PrintOptions / RenderOptions.
