Normal Topic Clear selection of nodes (Read 3182 times)
mandz
May 8th, 2013 at 8:43am
How do I clear all selected items (nodes and links)?  I've tried this:
Code (Javascript)
diagram.Selection.Items.Clear();
Problem is that the Selection is always empty, even if I select a node.
Kiran B
Re: Clear selection of nodes
Reply #1 - May 8th, 2013 at 9:15am
Could you please try this
   var selectedItems = diagram.getSelection();
Kiran B
Reply #2 - May 8th, 2013 at 9:33am
If you need to clear the selection on client side, you can access the selection object using diagram.getSelection() as Kiran noted, and then call its clear method:
diagram.getSelection().clear();
You can find the public JavaScript methods listed for each class here:
http://mindfusion.eu/onlinehelp/mvcdiagram/index.htm?CC_N_MindFusion_Diagramming...
mandz
Reply #3 - May 9th, 2013 at 12:25am
Thanks both for the reply.  I got it working.
