Normal Topic DiagramLink between two TreeviewItem (Read 1722 times)
Fred
May 8th, 2013 at 12:35pm
I have two TreeviewNode objects (node1 and node2) each having several TreeviewItem elements
I would like to "draw" a DiagramLink between a TreeviewItem of node 1 and a TreeviewItem of node2.
The TreeviewNodes show up correctly with the added TreeviewItems, but the DiagramLink is not visible.
Here is my code
        node1.AllowIncomingLinks = True
        node1.AllowOutgoingLinks = True
        node2.AllowIncomingLinks = True
        node2.AllowOutgoingLinks = True
        Dim lnk As New DiagramLink(MyDiagram)
        Dim conn1 As New TreeViewConnectionPoint(node1, lnk, False, ndeItem1)
        Dim conn2 As New TreeViewConnectionPoint(node2, lnk, True, ndeItem2)
        lnk.OriginConnection = conn2
        lnk.DestinationConnection = conn1
        ndeItem1.OutgoingLinks.Add(lnk)
        ndeItem2.IncomingLinks.Add(lnk)
Could someone please provide me a code sample to draw a DiagramLink between two TreeviewItem elements.
Thank you in advance
Fred
Re: DiagramLink between two TreeviewItem
Reply #1 - May 8th, 2013 at 1:00pm
Add the link to diagram.Links instead to nodes' collections, as in http://mindfusion.eu/Forum/YaBB.pl?num=1252378544/1#1. The nodes in/out collections will get updated automatically.
Fred
Reply #2 - May 8th, 2013 at 3:10pm
Yes, that solved my problem.
Thank you
