Normal Topic Offsetting the diagram BackgroundImage? (Read 1714 times)
ulthien
May 10th, 2013 at 4:01pm
trying to offset the background image of a diagram so its raster fits to nodes spacing:
<Presentation:DetailDiagram x:Name="NetDiagram" BackgroundImage="{StaticResource Cell_Grid}"
BackgroundImageAlign="Tile"
Focusable="False"
ShowAnchors="Auto"
BackBrush="{StaticResource DefaultBackgroundBrush}"
AlignToGrid="True"
GridSizeX="1"
GridSizeY="1"
ShapeHandlesStyle="HatchHandles3"
ShowGrid="False"
Behavior="DrawLinks"
ShapeBrush="DeepSkyBlue"
AllowDrop="True"
but there is no margin="" element to nudge the positioning of the background a bit, like 20 pixels...
repositionining the nodes themselves gets overriden, as somehow the backgroundimage "adapts" and jumps to same position again..
ulthien
Re: Offsetting the diagram BackgroundImage?
Reply #1 - May 10th, 2013 at 4:45pm
actually, the behaviour of the diagram background is different depending if i take
BackgroundImageAlign="Centered" or anything else.
Only Centered stays proportionally and positionally same on zooming in and out, all others scale wrong or slide aside.
Reply #2 - May 11th, 2013 at 8:29am
You can draw an image with offset from the DrawBackground event handler:
private void OnDrawBackground(object sender, DiagramEventArgs e)
	var img = Utilities.LoadImage("test.png");
	var rect = new Rect(160, 20, img.Width, img.Height);
	e.Graphics.DrawImage(img, rect);
