Normal Topic Disable/enable in-place edit on a node-by-node basis (Read 2239 times)
Rennie
May 12th, 2013 at 9:56am
I want in-place edit to work for some nodes and not for others. I've discovered that if I return RectangleF.Empty from the GetEditRect() method then this does effectively disable the in-place edit for that node.
Is this an OK technique that won't cause problems in future versions? If so, could you please add it to the documentation for GetEditRect(), so I can sleep peacefully at night?
Alternatively, if this isn't a technique you want to guarantee for the future, can you suggest another way to implement in-place edit for some nodes and not for others?
Thanks.
Re: Disable/enable in-place edit on a node-by-node basis
Reply #1 - May 13th, 2013 at 7:09am
That probably creates an invisible edit box. Better disable AllowInpalceEdit altogether, and call DiagramView.BeginEdit from NodeDoubleClicked handler only for the nodes you want it enabled.
Rennie
Reply #2 - May 13th, 2013 at 9:44am
OK, thanks.
