Normal Topic In a TabControl, use one or multiple DiagramView controls? (Read 2156 times)
Rennie
May 17th, 2013 at 12:32am
I'm implementing a window with a TabControl (actaully, the DevExpress XtraTabControl, but same concept), and the idea is that each tab will have a Diagram object associated with it. So if there are three tabs there will be three Diagram objects, and only one of them will be visible and modifyable.
My question: Do you recommend placing a DiagramView control on each tab, even though only one of them will be visible? Or do you recommend having one DiagramView control and moving it to the currently-visible tab and changing the DiagramView.Diagram field to reference the Diagram object for that tab?
(I'm aware that there's a TabbedDiagramView control, but I prefer to use the DevExpress one for various reasons.)
Thanks.
Rennie
Re: In a TabControl, use one or multiple DiagramView controls?
Reply #1 - May 17th, 2013 at 1:09pm
Never mind, I've decided to "fake it" by having no tabs on the tab control, just the tab headers, and place the DiagramView control below the tab control and try to make it look like it is actually on a tab.
Reply #2 - May 17th, 2013 at 1:12pm
I suppose this is up to your preference. I can see our developers are using a single view and changing its Diagram in TabbedDiagramView implementation.
