Normal Topic List of nodes on Diagram ordered by their location ?? (Read 2087 times)
Rich Cassell
May 20th, 2013 at 8:30am
We're using various different ways to search through our nodes based on their parent or their children or the level that they sit on in the flow etc. We have a need to have a tree-like structure which would mean no 2 nodes share the same y coordinate; from this, we need to use the "level" that they sit on to automatically select an entry in a list (i.e. the user selects the node at position 7 and entry 7 of a list is selected)...
The complication here is that our users are free to place nodes whereever they like, so, if you have 10 nodes on the canvas and they drop a new one onto node 4 then it'll create a tree within the tree, thus changing the locations of every other node.
Is there a simple command that gets a list of nodes which is ordered on their y or x location on the Diagram ?? I'm sure i can do this manually but i have a feeling it'll be very fiddly so i thought i'd check to see if there's one already there first!
I hope that all makes sense Smiley
Rich
Re: List of nodes on Diagram ordered by their location ??
Reply #1 - May 20th, 2013 at 10:25am
Try this:
var nodesByX = new List<DiagramNode>(diagram.Nodes);
nodesByX.Sort((node1, node2) =>
	node1.Bounds.X.CompareTo(node2.Bounds.X));
Rich Cassell
Reply #2 - May 20th, 2013 at 10:54am
Hi Stoyan.
Brilliant. Works a treat!
Thanks very much Smiley
Rich
