Normal Topic Selecting nodes programatically using javascript (Read 1836 times)
Kiran B
May 21st, 2013 at 12:19pm
I need to select the nodes programatically using JavaScript.
It should behave exactly same as manual selection. The selection handle has to come and the diagram.getSelection() should return the item also.
Is there any way?
Kiran B
Re: Selecting nodes programatically using javascript
Reply #1 - May 21st, 2013 at 2:26pm
Call node.setSelected(true);
