Normal Topic Any plans for a .net 4 client profile compatible version? (Read 1124 times)
Paul B
May 24th, 2013 at 4:30pm
From what I can see mindfusion.diagramming.winforms.dll relies on system.design which is only available in the full version of .net4. I'd like to target .net4 client profile in my application. Are there any versions that would work with this? Or are there any plans for such a version in the future?
Many thanks.
Re: Any plans for a .net 4 client profile compatible version?
Reply #1 - May 24th, 2013 at 5:08pm
The assembly from the /MindFusion Diagramming/CLR4 subfolder does not have e reference to the design.dll and you should be able to use it under the client profile.
