Normal Topic ArgumentOutOfRange in custom drawlinks behavior (Read 3522 times)
j poz
Jun 3rd, 2013 at 9:16pm
If the DiagramView.Behavior is set to Custom..
..and you are using a custom DrawLinksBehavior class..
If you rapidly click on a diagram link, an ArgumentOutOfRange exception gets thrown from the OnMouseMove.
Once the exception is thrown it also stops drawing the link correctly.
Re: ArgumentOutOfRange in custom drawlinks behavior
Reply #1 - Jun 4th, 2013 at 7:27am
Please post the exception stack trace and behavior class code.
j poz
Reply #2 - Jun 4th, 2013 at 2:43pm
Here is an example class that replicates the problem:
public class TestDrawLinksBehavior : DrawLinksBehavior
        protected internal TestDrawLinksBehavior(DiagramView diagramView) : base(diagramView)
        public override InteractionState StartDraw(PointF point)
            DiagramItem ac = Diagram.ActiveItem;
            int handle = 0;
            var hitTest = false;
            if (ac != null)
                hitTest = ac.HitTestHandle(point, ref handle);
                if (!hitTest && handle == 0 && ac.ContainsPoint(point))
                    //Force the move handle
                    handle = 8;
                    hitTest = true;
            // Any interactive item (move, handles, containers, etc.)
            if (ac != null && Diagram.IsItemInteractive(ac) && hitTest)
                return new InteractionState(ac, handle, MindFusion.Diagramming.Action.Modify);
            else // Selecting tools
                return new InteractionState(Diagram.Selection, -1, MindFusion.Diagramming.Action.Create);
j poz
Reply #3 - Jun 4th, 2013 at 2:44pm
Here is the stack trace:
   at System.Collections.CollectionBase.System.Collections.IList.get_Item(Int32 index)
   at MindFusion.Diagramming.PointCollection.get_Item(Int32 index)
   at MindFusion.Diagramming.DiagramLink.UpdateModify(PointF current, InteractionState ist)
   at MindFusion.Diagramming.InteractionState.Update(PointF point, Diagram diagram)
   at MindFusion.Diagramming.WinForms.Behaviors.BehaviorBase.OnMouseMove(Point mousePosition)
   at MindFusion.Diagramming.WinForms.DiagramView.OnMouseMove(MouseEventArgs e)
   at System.Windows.Forms.Control.WmMouseMove(Message& m)
   at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
   at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
   at System.Windows.Forms.Application.Run(Form mainForm)
   at AlteryxGuiToolkit.Main.StartApp(String[] args) in s:\Alteryx\AlteryxGuiToolkit\Main.cs:line 187
   at AlteryxGui.CMain.Main(String[] args) in s:\Alteryx\AlteryxGui\Main.cs:line 68
   at System.AppDomain._nExecuteAssembly(RuntimeAssembly assembly, String[] args)
   at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
   at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
   at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Threading.ThreadHelper.ThreadStart()
j poz
Reply #4 - Jun 4th, 2013 at 2:51pm
It seems like commenting out this line stops the exception from happening:
However, the exception doesn't get thrown from inside of InteractionState so you can't simply put a try/catch around this line..
Reply #5 - Jun 4th, 2013 at 4:06pm
The handle index you pass to InteractionState constructor is later directly used as index within the link's ControlPoints collection, so the handle = 8 assignment will cause an exception if the active item is link with fewer than 9 points. Try adding an additional check for ac type to the if statement around that assignment:
if (ac is DiagramNode && !hitTest && handle == 0 && ac.ContainsPoint(point))
j poz
Reply #6 - Jun 4th, 2013 at 4:49pm
That worked. Thank you.
