Normal Topic Hide the drag corners (the 8 big squares) (Read 3857 times)
developer
Jun 5th, 2013 at 8:16am
I want to disabled the node edit and hide the drag corners (the 8 big squares) that appear around the corners. I tried:
node.EnabledHandles = AdjustmentHandles.None;
No result. How I get it?
Thanks!
Re: Hide the drag corners (the 8 big squares)
Reply #1 - Jun 5th, 2013 at 11:12am
We haven't implemented EnabeldHandles yet in the JavaScript library. At this time you can prevent both modification and selection by setting the Locked property.
If you want to let users select items but not modify them, call args.cancelDrag() from the nodeModifying event handler. In that case you can hide the handles by overriding the nodes' addHandlesToCanvas method:
var originalAddHandles = ShapeNode.prototype.addHandlesToCanvas;
ShapeNode.prototype.addHandlesToCanvas = function (point)
	originalAddHandles.apply(this, []);
	Array.forEach(this.handles, function (handle)
		handle.brush = "transparent";
		handle.pen = "transparent";
developer
Reply #2 - Jun 5th, 2013 at 2:24pm
Thanks for the reply.
I disabled the node edit and hide but i cant hide the drag corners (the 8 big squares) that appear around the node.
Could you upload a small example of how to override the function?
Thanks.
Reply #3 - Jun 6th, 2013 at 7:12am
You can find a sample project here:
https://mindfusion.eu/_samples/HideHandles.zip
The code is in the page load handler of Views/Home/Index.cshtml.
developer
Reply #4 - Jun 6th, 2013 at 7:29am
Yeah!. Thank you so much.
