Normal Topic GetBaseShapeDefinition doesnt exist in version 6 ? (Read 2094 times)
farshid
Jun 6th, 2013 at 1:57pm
Hi
Is there any documentation for the breaking changes for update version 6.
I am trying to update to use the latest version of the MindFusion.Diagramming (6.0.2.23846).
Public Shared Sub Test(ByVal e As MindFusion.Diagramming.DrawLinkEventArgs)
     Dim headCoordinates As Single() = e.Link.GetBaseShapeDefinition.Coordinates
     Dim polygonPoints As New Generic.List(Of System.Drawing.PointF)
     While i < headCoordinates.GetUpperBound(0)
           polygonPoints.Add(New System.Drawing.PointF(headCoordinates(i), headCoordinates(i + 1)))
           i += 2
     End While
End Sub
My problem is that GetBaseShapeDefinition doesnt exist in the latest version. How do I access the Coordinates of the shape from the DrawLinkEventArgs?
Your help is very much appreciated.
Kind regards
Farshid
Re: GetBaseShapeDefinition doesnt exist in version 6 ?
Reply #1 - Jun 6th, 2013 at 2:56pm
The changes are listed here:
http://www.mindfusion.eu/onlinehelp/flowchartnet/index.htm?Moving_to_MindFusion_...
However this error probably happens because of an earlier change in v5.3.4, when the arrowhead property types were changed from enum Arrowhead to class Shape. Now you can enumerate the Shape.Outline elements and check their coordinates, but you will need to scale them from percents to values corresponding to the arrowhead size.
farshid
Reply #2 - Jun 10th, 2013 at 10:29am
Hi
Thank you for your rapid reply. I don't understand what you mean by "but you will need to scale them from percents to values corresponding to the arrowhead size.” Below is the changes that I have made. Is this what you mean? I would appreciate if you could give an examples.
     Dim headCoordinates As PointCollection = e.Link.GetOutlinePoly(True)
     While i < e.Link.HeadShape.ShapeDecorations.GetUpperBound(0)
            polygonPoints.Add(headCoordinates(i))
            i += 1
     End While
     e.Graphics.FillPolygon(Brushes.Black, polygonPoints.ToArray())
End Sub
Thank you.
Kind regards,
Farshid
Reply #3 - Jun 10th, 2013 at 11:39am
Do you need this only to draw the arrowhead from custom drawing code? You could use the static DrawArrowhead method for that:
private void diagram_DrawLink(object sender, DrawLinkEventArgs e)
	var transparent = new System.Drawing.Pen(Color.Transparent);
	DiagramLink.DrawArrowhead(
		e.Graphics,
		transparent,
		Brushes.Black,
		e.Link.BaseShape,
		new PointF(50, 0),
		e.Link.ControlPoints[0],
		e.Link.ControlPoints[1],
		e.Link.BaseShapeSize,
		false);
	transparent.Dispose();
