Normal Topic Issue with setting VirtualScroll to true in latest release (Read 1812 times)
Aby
Jun 6th, 2013 at 2:33pm
Hi All,
I've a "Properties" pane, which expands when I click it over the canvas. This was showing up correctly till I tried the setVirtualScroll to true.
Now the div is going under the canvas.
Any help is much appreciated.
Attached is the screenshot of the issue. I've marked in red where the div is going behind canvas.
Aby
Re: Issue with setting VirtualScroll to true in latest release
Reply #1 - Jun 6th, 2013 at 3:00pm
In this mode the canvas is moved out of the div, and canvas.style.zIndex is set to 1. Try setting ZIndex of your property pane to a value larger than 1.
