Here is the Stack Trace...
System.Data.SqlClient.SqlException Message=The DELETE statement conflicted with the REFERENCE constraint "Item_FK03". The conflict occurred in database "DashboardPlannerSQL1", table "dbo.Item", column 'Style'. The statement has been terminated. Source=.Net SqlClient Data Provider StackTrace: at System.Data.Common.DbDataAdapter.UpdatedRowStatusErrors(RowUpdatedEventArgs rowUpdatedEvent, BatchCommandInfo[] batchCommands, Int32 commandCount) at System.Data.Common.DbDataAdapter.UpdatedRowStatus(RowUpdatedEventArgs rowUpdatedEvent, BatchCommandInfo[] batchCommands, Int32 commandCount) at System.Data.Common.DbDataAdapter.Update(DataRow[] dataRows, DataTableMapping tableMapping) at System.Data.Common.DbDataAdapter.UpdateFromDataTable(DataTable dataTable, DataTableMapping tableMapping) at System.Data.Common.DbDataAdapter.Update(DataSet dataSet, String srcTable) at System.Data.Common.DbDataAdapter.Update(DataSet dataSet) at MindFusion.Scheduling.DataBinding.x8db18c2080b4ae64.x836093ae8ca8dd2e(Boolean xd441e330aca0adbe) at MindFusion.Scheduling.DataBinding.xa7e178e5abda1bf4.x3967b919ae7ea836(Boolean xd441e330aca0adbe) at MindFusion.Scheduling.WinForms.Calendar.SaveToDataSource(Component reminderTableAdapter, Component styleTableAdapter, Component customBrushesTableAdapter, Component contactTableAdapter, Component locationTableAdapter, Component resourceTableAdapter, Component taskTableAdapter, Component itemTableAdapter, Component itemContactsTableAdapter, Component itemResourcesTableAdapter, Component recurrenceTableAdapter, Component recurrenceExceptionTableAdapter, Component recurrenceExceptionsTableAdapter) at WindowsApplication1.frmDashboard.SaveToolStripButton_Click(Object sender, EventArgs e) in C:\Users\valued customer\Documents\Visual Studio 2012\Projects\ProjectDashboard\ProjectDashboard\Dashboard.vb:line 98Int32 UpdatedRowStatusErrors(System.Data.Common.RowUpdatedEventArgs, BatchCommandInfo[], Int32) InnerException:
