Normal Topic Diagramming for Windows Forms, V6.0.3 (Read 2589 times)
Jun 11th, 2013 at 11:24am
We have released version 6.0.3 of FlowChart.NET. It adds the following customer-requested features:
ContainerNode improvements
  • child nodes are now drawn by their containers; when containers overlap, the children of a lower container cannot appear in front of the upper container anymore
  • the ClipChildren property specifies whether to clip child items to container’s boundaries
  • the ZIndex property no longer changes automatically when dropping nodes into a container
  • the Visible property of child items no longer changes when folding or unfolding containers; this lets you keep invisible items inside containers
  • when selection including a container and its child node is dropped into another container, the child node now remains in its original container
PdfExporter improvements
  • improved handling of clip regions in custom drawing code
  • PdfExporter now honors the target Rectangle property of linear gradients
  • PDF shadings now include all colors from a ColorBlend
  • more precise character widths set when text includes both eastern glyphs and Latin characters
  • more precise widths set for Cyrillic characters
New events
  • the SetSelfLoopShape event is raised when a link becomes a self-loop, giving you a chance to set a custom shape for the link
  • QueryAlignTarget event is raised to determine if a node should be used as alignment guide target when AutoAlignNodes is enabled.
  • NegatedX and NegatedY properties added to Ruler control
  • CatchGdiPlusExceptions property now works for nodes too
  • now HtmlBuilder can create areas for TreeViewNode items
  • public Sort methods added to diagram item collection classes
