Normal Topic Resizing Image node issue (Read 2398 times)
Kyle Chen
Jun 25th, 2013 at 3:18pm
Hi Stoyan,
I recently had a issue in resizing a node with an Image. When enlarging it by dragging on left center handle, the image will have a missing block on the right - just not drawing like clipped out. I'm recreating the image dynamically and update it to node in NodeModifying event.
However there's no problem when enlarging with right center handle. Will you please look into it? Thanks.
I attached a screenshot here.
Kyle
Re: Resizing Image node issue
Reply #1 - Jun 25th, 2013 at 3:46pm
Are you sure you aren't missing setting the right-side pixels when recreating that image? If that's a standard ShapeNode, also check if ImageAlign isn't set to one of the *Left values.
Kyle Chen
Reply #2 - Jun 25th, 2013 at 7:07pm
Yes, I'm sure the whole bitmap created. I'm using the e.Node.Bounds.Size to generate result bitmap. And I was set to TopLeft. And I just tested, when I set to Fit, it still the same. Only left dragging clip the image(kept only the same width of image - looks like some image buffer?)
Thanks.
Reply #3 - Jun 26th, 2013 at 7:14am
Please attach a test project that shows the problem.
Kyle Chen
Reply #4 - Jun 26th, 2013 at 2:58pm
Stoyo wrote on Jun 26th, 2013 at 7:14am:
Hi Stoyan,
When I prepare the project for you. I found it's my problem. I did the clip at some special case. Sorry for that and thank you for your time! Respect your confidence to your product.
Kyle
