Hot Topic (More than 10 Replies) Positioning labels optimally (Read 10012 times)
DavidZ
Re: Positioning labels optimally
Reply #15 - Jul 2nd, 2013 at 3:51pm
I first create the boxes with a default value for bounds e.g. 50,2,50,30
There is also some default text: "Needs Update"
The font is created as :
box.Font = New Font("Arial", 2.6, GraphicsUnit.World)
I then set the text to "Category field (on a Constituent Attribute) is one of the following; Origin for at least one Constituent Attribute record?"
I set the box.TextPadding = new Thickness(3)
and then I do a box.ResizeToFitText.
At this point it is not connected with any links.
A bit later the links are added.
I then lay out the boxes
I then route them with the orthogonal router.
I then do Diagram.ResizeFitItems(5)
and then a Diagram.ArrangeLinkLabels
David
Reply #16 - Jul 3rd, 2013 at 7:10am
I have tried the following with the sample file you attached earlier but cannot see any labels overlapping nodes:
diagram.LoadFromXml("diagram_001.xml");
foreach (ShapeNode node in diagram.Nodes)
	node.Font = new Font("Arial", 2.6f, GraphicsUnit.World);
	node.Text =
		"Category field (on a Constituent Attribute) is one of the following; Origin for at least one Constituent Attribute record?";
	node.TextPadding = new Thickness(3);
	node.ResizeToFitText(FitSize.KeepRatio);
new OrthogonalRouter().Arrange(diagram);
diagram.ResizeToFitItems(5);
diagram.ArrangeLinkLabels();
Could you save and attach the diagram in which you see overlapping?
DavidZ
Reply #17 - Jul 3rd, 2013 at 12:51pm
I am attaching the image and the xml file.
David
flowchart.txt (Attachment deleted)
Reply #18 - Jul 4th, 2013 at 8:18am
Try a new version from the PM page.
DavidZ
Reply #19 - Jul 4th, 2013 at 11:06am
Yay!!
Thanks. Looks good.
David
