Normal Topic different colour for weekends (Read 4124 times)
alexFM
Jul 8th, 2013 at 1:37pm
I'm sorry to bother you, but I wanted to know how can I show the weekend in a different colour as the rest of the days in all of my resources?
I wanted to see if there is an easy way of achieving this or I need to come up with something a little bit more complicated.
Thanks for your time.
Re: different colour for weekends
Reply #1 - Jul 8th, 2013 at 1:51pm
If you are using the ResourceView, you can set the weekend color like this:
calendar.ResourceViewSettings.WeekendStyle.Brush = new MindFusion.Drawing.SolidBrush(Color.Red);
Let me know if this helps.
alexFM
Reply #2 - Jul 8th, 2013 at 3:46pm
I have tried that, but it doesn't work.
Any other way of showing the weekends?
Reply #3 - Jul 9th, 2013 at 5:41am
Can you attach a sample illustrating the scenario where this property does not work?
alexFM
Reply #4 - Jul 9th, 2013 at 8:36am
This is how my calendar looks like and I want to show the Saturdays and Sundays in a different colour.
Any changes in the display would be appreciated.
Thank you!
Reply #5 - Jul 9th, 2013 at 10:09am
If you are using custom drawing for the resource view cells, you need to manually paint the weekend cells differently. You can check the DrawEventArgs.Date property. If it is Saturday or Sunday, simply use different fill brush.
If you are using the Resource.CustomBrushes properties, then SecondaryBrush will be used for the weekend cells.
