Normal Topic Custom nodes? (Read 3198 times)
Rennie
Custom nodes?
Jul 12th, 2013 at 4:25pm
This is an amazing coincidence - I'm finally finished with the WinForms part of my program and I'm just starting to get into Android programming. And now MindFusion releases this viewer program! Great!
But - I worry about one thing. My program is very much based on a lot of custom nodes, both custom composite nodes and custom nodes derived directly from DiagramNode. Is this a problem? Is there any workaround?
Thanks.
Re: Custom nodes?
Reply #1 - Jul 13th, 2013 at 11:16am
You will have to port the drawing and XML deserialization part of your nodes to Java, e.g.:
Diagram.registerItemClass(MyNode.class, "MyNode", 1);
public class MyNode extends DiagramNode
    protected void drawLocal(Canvas graphics, RenderOptions options)
        // use Canvas API to draw node's elements
    protected void loadFromXml(Element xmlElement, XmlPersistContext context)
        super.loadFromXml(xmlElement, context);
        // use XmlPersistContext API to load properties
Composite nodes are not supported at this time. You could still load them using a custom class registered with same ID, and render some representation of their components using Canvas methods.
