Normal Topic Are OnNodeClicked and NodeClickedScript mutually exclusive? (Read 2557 times)
jlj30
Jul 17th, 2013 at 4:24pm
For the most part, I want to handle the nodeClicked event in Javascript, but on occasion I need to deal with it in code behind.
I can cause a postback using some other techniques, but I just wanted to clarify that the server side event will not fire, if I have NodeClickedScript specified.
Here's what I was hoping would work:
Code (Javascript)
function onClientNodeClicked(sender, args)
                var tag = args.getNode().getTag();
                switch (tag)
                    case "client":
                        // handle this right here
                        args.set_cancel(true);
                        break;
		    case "server"
			// Don't cancel this request - allow code behind to handle
			args.set_cancel(false);
			break;
Thanks in advance.
Jim
Re: Are OnNodeClicked and NodeClickedScript mutually exclusive?
Reply #1 - Jul 18th, 2013 at 10:52am
Yes, they are mutually exclusive, there's no post-back script generated for nodes if either NodeClickedScript or NodeDoubleClickedScript is set.
You should be able to implement that easily by leaving NodeClickedScript unset, and instead handling the CreatingAreaElement event. You can add an onclick attribute from the CreatingArea event handler only for some nodes, and the control will not generate post-back click handlers for them. The remaining nodes will post back automatically and raise the server side click event.
jlj30
Reply #2 - Jul 18th, 2013 at 12:45pm
Good advice as always.
Jim
