Normal Topic Getting the Tag value for an attached node (Read 2030 times)
jlj30
Jul 17th, 2013 at 7:53pm
I was using the following in code behind and it worked fine:
Session["SubProcess_Task_Prefix"] = e.Node.MasterGroup.MainItem.Tag.ToString();
I have a node that I have "attached" to another using the AttachTo method.
I now want to accomplish the same thing in Javascript, and tried the following:
Code (Javascript)
function onClientNodeClicked(sender, args)
	var node = args.getNode();
	var taskTag = node.getMasterGroup().getMainItem().getTag();
        alert(taskTag);
The alert does not fire.
What am I doing wrong?
Jim
Re: Getting the Tag value for an attached node
Reply #1 - Jul 18th, 2013 at 12:40pm
If this is ImageMap mode, you can call only node.getTag() from a JavaScript event handler. No other properties of the node are transferred to the client side.
jlj30
Reply #2 - Jul 18th, 2013 at 12:44pm
Thanks.  I'll try appending the parent shape's tag info to the node that was clicked.
Jim
